Home » Sponsored » Pi Speakers » BMS compression drivers and Pi ?
Re: BMS compression drivers and Pi ? [message #43753 is a reply to message #43752] Thu, 22 January 2004 09:20 Go to previous messageGo to previous message
andreas paulsen is currently offline  andreas paulsen
Hmm the focal high end drivers are quite sensitive, my one is a dedicated pro audio midrange with a sensitivity of 98-99 db/1w/1m. I cannot be to sure as I havent got a spec sheet or a calibrated mic.
the fs at 110Hz is a bit high though for a low crossover frequency
In general the focal stuff is more sensitive than scan-speak og vifa type of drivers.
cheers
andreas
Previous Topic: can the 2445J use in the pro 4 instead of the 2426?
Next Topic: baffle spacing, vertical alignment
Current Time: Thu Nov 05 22:22:34 CST 2026
