Home » Sponsored » Pi Speakers » 10-pi plan request
You've got mail! [message #43724 is a reply to message #43720] Mon, 19 January 2004 22:41 Go to previous message
Paramours don't seem to be as sensitive to the woofer's impedance fluxuations in the resonance region as do some other SET amplifiers.
So you have a few more loudspeaker options than I would recommend for other SET amp owners. Four examples that I really like are the Theater Series three π, the Theater Series six π, the Stage Series four π and the Stage Series seven π. I haven't tried the Audiophile Series seven π-18, but I'll bet it is an absolute killer on a well-built pair of Paramours too.
The Professional Series four π, seven π and ten π loudspeakers aren't the best suited for SET amps, but they aren't the worst either. Their efficiency is good, and their impedance curve is acceptable, but it's a close call. Some SET amps sound a bit anemic on them, but the Paramours work great with each of them.
One thing about the ten π's - If you have two good corners, I think you'd be happier with seven π cornerhorns instead. If you have only one good corner or something like that, the ten's are great along walls where seven π's could not be used. But unless the room is huge, the speakers are so large they are intrusive.
Previous Topic: rooms
Next Topic: foam horns and heavy drivers
Current Time: Tue Sep 22 01:36:58 CDT 2026
