Home » Sponsored » Pi Speakers » 2 pi tower placement
Re: 2 pi tower placement [message #43708 is a reply to message #43707] Sat, 17 January 2004 17:40 Go to previous messageGo to previous message
Routing a recess is a nice touch for looks and if you make it a flush mount you might pick up a little baffle diffraction bennefit. For a standard 3/4" thick baffle I like to make a 3/16-1/4 deep recess. Rout in the recess pocket first with a 3/4" cutter. Then core through for the basket hole with your 1/4" cutter.
Remember if your using a routing jig like the Jasper that the dimensions are for a 1/4" cutter so you have to recalculate for a 3/4" cutter
For a flush mount its pretty much the same. You just need to have a double baffle (two layers) so you can rout the recess posket deep enough for the driver to sit flush.
Bill
Previous Topic: 4PI: 15" vs 18" versions.
Next Topic: rooms
Current Time: Thu Sep 24 20:28:13 CDT 2026
