Home » Sponsored » Pi Speakers » pi corner horn
Re: pi corner horn [message #43689 is a reply to message #43680] Fri, 16 January 2004 09:32 Go to previous messageGo to previous message
David Morrison is currently offline  David Morrison
The box it is in now sound good with good spl too.
However i do have another sub sitting a closet at home would this work better for the first try (rec box 1.0-1.75 cu ft)
it t-s parameter are below.
Diameter 10 in
Mag Weight 102 oz
Freq Range 30-200Hz
Nom Imp 2 x 4ohm
RE 2 x 2.10 ohm
Fs 30 Hz
Qts 0.41
Qes 0.44
Qms 6.32
SD 54 In^2
Vas .99ft^3 28 L
Cms 1.60E-04 m/N
Mms 6.09 0z
VC Diameter 3 In
VC 5 Mil Aluminum
VC Ind 2.10 mH
BL 12.6 Tm
Xmax 14 mm
SPL 85 dB
Power 500 W RMS/1000W Peak
Previous Topic: Some Newbie Questions
Next Topic: Audiophile parts?
Current Time: Sun Nov 01 05:33:12 CST 2026
