Home » Sponsored » Pi Speakers » Used JBL 2426J in PI?
Re: Also want to know about 2370A Flare [message #43672 is a reply to message #43669] Thu, 15 January 2004 14:58 Go to previous messageGo to previous message
Used 2426's can sometimes have damaged or second-source diaphragms. You can use 16 ohm versions, although as you've noted, the crossover was designed for 8 ohm devices. We discussed the values here, so you might try a search. I'll rummage around and see if I can find this information too. As for the horn flare, the H290 is much smaller and shouldn't be used below 1kHz. I'd keep 'em above 1.2kHz, which is OK since the PSD2002 really needs to be crossed higher too. The JBL 2370 is a much larger horn and can be used down to 800Hz.
Previous Topic: No more games
Next Topic: R-13 placement
Current Time: Fri Nov 06 03:12:10 CST 2026
