Home » Sponsored » Pi Speakers » pi corner horn
Re: pi corner horn [message #43642 is a reply to message #43640] Tue, 13 January 2004 11:03 Go to previous messageGo to previous message
Dean Kukral is currently offline  Dean Kukral
If I get this correct, then:
This design permits you to use a higher crossover than with a Klipsch-type folded corner horn, doesn't it? Thus, you are able to use a two-way system with full compression horn loading above the woofer? (Avoiding the need of the "Holy Grail" midrange.)
Previous Topic: Some Newbie Questions
Next Topic: Audiophile parts?
Current Time: Sun Nov 01 07:23:21 CST 2026
