Home » Sponsored » Pi Speakers » Crossover Document
Re: Oh, made an error [message #43637 is a reply to message #43634] Tue, 13 January 2004 09:06 Go to previous messageGo to previous message
The illustration with the Linkwitz formula shows the forward axis is straight in front, but does mention hat it can be shifted by driver position front or back. It is also shifted by crossover phase. The two aren't the same kinds of delay, but if the overlap band is narrow enough, the effects will be pretty much the same. Crossover phase shifts delay by a moving amount proportional to frequency, but this movement is small if the overlap band is small. If the crossover uses low-order slopes, then the crosover band will be wide enough that the null angles will shift through the overlap band, effectively creating a wider null area.
Previous Topic: Great Plains Audio Community Meeting - Pics
Next Topic: Montreal Pi
Current Time: Thu Nov 26 11:35:13 CST 2026
