Home » Sponsored » Pi Speakers » Pro essional 7 Pi's with 2123J midrange
Re: Professional 7 Pi's with 2123J midrange [message #43616 is a reply to message #43612] Sun, 11 January 2004 11:28 Go to previous message
The seven π's in the early eighties with 2205 woofers used a pair of 2105's for midrange, and they weren't horn loaded. I've also made a seven π using a 2245 bass bin and 2123 direct radiating midrange.
But I think there are advantages to using a horn loaded midrange too, one that matches directivity at 90° horizontal and with limited vertical pattern too. The corner limits the radiating angle, to be sure, but at higher frequencies it is nice to have the pattern control, reducing early reflections. It also allows the vertical pattern to be set within the nulls. That's another thing to consider, a possibility worth looking at. A midhorn like this is relatively easy to build.
Previous Topic: I brought this over from the tube section
Next Topic: How much does a Theatre Four Pi weigh? n
Current Time: Fri Nov 13 06:48:15 CST 2026
