Home » Sponsored » Pi Speakers » Do I "need" a subwoofer?
Re: Do I "need" a subwoofer? [message #43609 is a reply to message #43608] Sat, 10 January 2004 12:39 Go to previous messageGo to previous message
There are folks running 6" single driver speakers that are happy with the bass, although it really isn't getting much lower than 100Hz. Then there are others that want the 20-40Hz octave EQ'ed up louder than the mids.
As for me, if a system's response doesn't reach 60Hz flat, it sounds lacking. If it can reach 40Hz flat, then it sounds pretty good and full. And the futher down it reaches, the better, because I can really notice the difference between a speaker with f3 of 30Hz and one with f3 of 40Hz. The 40Hz speaker sounds full, but the 30Hz speaker sounds even more so.
That's just a matter of quantity though. As long as we're hitting 40Hz, quality becomes more important to me. Adding subs adds bass sound sources, and this smoothes room modes. So the benefit of adding subs isn't just about extension, it's also about sound quality.
Previous Topic: How much does a Theatre Four Pi weigh? n
Next Topic: 2pi Tower Plans
Current Time: Fri Nov 13 06:29:48 CST 2026
