Home » Sponsored » Pi Speakers » What to do with these
What to do with these [message #43546] Fri, 02 January 2004 21:18 Go to previous message
I have these two tractrix horns from ages ago now sitting around. Perhaps I should make some sort of rear speaker out of them? Whats the requirement for THX?
Dolby Pro Logic is meant to roll off around 5-7KHz on the high end, getting a tweeter should be easy then.
Horn response of the tractrix loaded with alpha 6, way outdoors 1m on axis:
I guess I could use it to 1.4KHz. Should I use a horn tweeter with it? I dont want another horn/comp driver combo, too much effort (and money). I guess I just want to use these tractrix for something, as they are sitting around doing nothing and I put a lot of work in them (unlike the easy conicals I did haha). would need to buy another pair of alpha 6's.
I would have posted this on the home theatre roundtable forum, but it appears very little people go there :(
Adrian
Previous Topic: PI 2 Plans,
Next Topic: 4 pi theater plans, pleeze...
Current Time: Sat Nov 14 16:54:14 CST 2026
