Home » Sponsored » Pi Speakers » Some Pics of Bill E's refurbished cabs
Re: Nice job Craig [message #43529 is a reply to message #43523] Wed, 31 December 2003 15:38 Go to previous messageGo to previous message
drguayo is currently offline  drguayo
Hi:
Thanks everyone for the great feedback. My next project will be better! I promise.
I used the spray glue also.
I stapled 1 end first then spray glued generously and then put down the leather and then used a rolling pin - then stapled the far end.
Right after it was laid it looked great. 4 hours later there were air bubbles then when I woke up in the morning everything was flat and smooth. I was working in my friend's cold garage when I applied the glue which may have caused the air bubbles later due to the glue giving off gases with heat increase after I brought them into the house.
Some day I hope to have a proper work space for all this and won't be working in the cold Canadian winter(although this year it's very mild)
regards
craig.
Previous Topic: budget eminence clone
Next Topic: Happy New Years!
Current Time: Sun Nov 01 21:32:13 CST 2026
