Home » Sponsored » Pi Speakers » progess pics
Some new pictures [message #43450 is a reply to message #43435] Wed, 24 December 2003 04:17 Go to previous messageGo to previous message
Just thought I'd put up some new pictures
Above shows the whole thing tipped on its side. That fibreglass you see is not really needed. The section it is in is completely closed off from the woofer chamber, its just wasted space actually. So it was probably a waste, but oh well - I got a ton of the stuff anyway.
Above shows enclosure with sides attached
Above shows box with sides and top attached.
Still gotta attach all this stuff to the other tower, then I gotta put in the lips for the back panel, as the top half is removable. Then all the odds and ends, like sanding down bumps, cutting and drilling holes for terminal cups + components, finishing etc.
Previous Topic: JBl 2235
Next Topic: It Never Stops! How about PSD2002 in 2PI Towers?
Current Time: Mon Oct 12 10:32:54 CDT 2026
