Home » Sponsored » Pi Speakers » Do all 15 Eminence drivers have same mount pattern?
Re: They are for my Karlson cabinets [message #43419 is a reply to message #43418] Fri, 19 December 2003 17:16 Go to previous message
You could use the Eminence Omega 15 with good results, but I don't think I'd use the Beta 15. In fact, I don't think you'll find acceptable performance when substituting any of the pressed-frame Eminence 15" models, because the cabinet size will probably be wrong.
The Eminence Beta 15 is tuned quite differently than a Kilomax 15, needing a much larger box. The Kilomax 15 performs well in relatively small cabinets between about 3ft3 and 8ft3 but the Beta 15 needs a much larger box. The Beta 15 should be used in cabinets no smaller than 5ft3, and would work well in boxes as large as 30ft3. If your cabinet is between 5ft3 and 8ft3 or so, you can probably do the swap, although you'll most likely need to change the port.
Previous Topic: Guys, help me design a smokin' midrange horn...
Next Topic: Re: Update
Current Time: Sun Nov 01 19:01:20 CST 2026
