Home » Sponsored » Pi Speakers » Big day of measurements and stuff, long post
Re: Phase plugs [message #43365 is a reply to message #43364] Sat, 13 December 2003 17:40 Go to previous messageGo to previous message
If it peaks down low with and without your phase plug installed, then I doubt a phase plug of different shape will correct the problem. If the disk had begun to vibrate with a resonant in the midrange, I could have understood it causing those peaks. But it must be something else. Maybe extend the mouth or put it on a large baffle and see what happens. That will help you isolate the flare, because its characteristics will change. Kinda looks like a mechanical buzz to me though. Or it might be a measurement anomaly; May want to check the raw driver dismounted from the horn.
Previous Topic: All JBLPRO and Altec Home Theatre (almost) Hubba-Hubba!
Next Topic: Apocalypse!
Current Time: Fri Oct 23 09:26:19 CDT 2026
