Home » Sponsored » Pi Speakers » crossover help
Re: crossover help [message #43336 is a reply to message #43334] Thu, 11 December 2003 11:34 Go to previous messageGo to previous message
When using an Altec horn atop a direct radiator, you'll want some padding of the horns. The attenuator will serve double-duty as the damper circuit and can provide top-octave compensation as well. I'd put a standard Zobel on the midwoofer. Other than that, the second-order network you've described will work just fine if you cross-connect the tweeter, wiring "+" to "-". The tweeter motor and the woofer motor should be aligned vertically, within four inches front to back. That gives you a pretty wide position tolerance window where performance will be good.
Previous Topic: In-wall speaker kits/plans
Next Topic: All JBLPRO and Altec Home Theatre (almost) Hubba-Hubba!
Current Time: Mon Nov 02 02:46:18 CST 2026
