Home » Sponsored » Pi Speakers » Hmmmm
Re: JBL 2105 [message #43328 is a reply to message #43320] Wed, 10 December 2003 14:29 Go to previous messageGo to previous message
djstan is currently offline  djstan
I've been looking at some pro sites that use conical horns and found the Yorkville tx8's use a conical 8 inch midrange and most, if not all the mid driver can be seen in the throat area. The Electrovoice Variplex II pretty much the same. They use 8 inch mids however, the Yorkville using Audax mids which interests me because I have 4 Audax 8inch mids (HT210T0 almost ruler flat from 200 to 6khz) and want to put them on a conical horn. Maybe this is the route to go?
Also from the Electrovoice picture it looks like it has a one to 3 inch straight throat before it enters the concial horn. What effect would this have? Increase high frequency extension?
Previous Topic: Help needed for old JBL D131 and new mr/tw horn
Next Topic: Why can't you use a single line array module on its own???
Current Time: Fri Nov 27 05:18:35 CST 2026
