Home » Sponsored » Pi Speakers » same speakers
Power handling and compression [message #43296 is a reply to message #43295] Mon, 08 December 2003 12:58 Go to previous messageGo to previous message
The speaker with greater power handling capacity is better able to dissipate power in the voice coil conductor, either because of improved materials or more likely because of better cooling ability. Improved cooling ability is usually the result of venting or other similar heat transfer mechanism.
A speaker with improved power handling will also suffer less compression than a comparible speaker with a lower thermal limit. For example, at 100 watts, the speaker with higher capacity my only have 0.5dB compression while the speaker with lower limits may already be at 3dB compression or more.
Previous Topic: Theater 4s rule!
Next Topic: What are compensation networks?
Current Time: Wed Oct 21 15:57:36 CDT 2026
