Home » Sponsored » Pi Speakers » help: pi alignmemt for JBL E155 (box & port)
Re: help: pi alignmemt for JBL E155 (box & port) [message #43258 is a reply to message #43252] Wed, 03 December 2003 17:08 Go to previous messageGo to previous message
PiAlign recommends a 3.0ft3 cabinet tuned to 56Hz using a port that's 5.25" x 9.375" and 7.25" long. Performance is very good using this cabinet. I wouldn't recommend tuning at 30Hz unless the cabinet were made much larger - around 8ft3 - in which case you will have generated an EBS alignment. Trouble is that this will reduce output below 100Hz -6dB.
The PiAligned 3ft3 56Hz cabinet provides flat response with f3 of 60Hz. The 8ft3 30Hz EBS alignment is -6dB down below 100Hz, but stays at this level down to 30Hz and the shelf is flat. Both are pretty good solutions, depending on your application.
Previous Topic: Need one JBL2227HPL and an box advice
Next Topic: Question on Theater 4 Dimensions
Current Time: Thu Nov 05 22:40:48 CST 2026
