Home » Sponsored » Pi Speakers » Pi Crossover
Things and stuff [message #43242 is a reply to message #43240] Mon, 01 December 2003 21:59 Go to previous message
Your diagram is exactly right. On the tweeter cable assembly, there are two leads that connect to the crossover PCB and two leads that connect to the tweeter. As far as polarity is concerned, it doesn't matter as long as something external to the circuit doesn't short it out.
Let me tell you why I said that. If you connect all the components on the "+" side of the circuit and then put them all in a metal chassis with the "-" side of the circuit being common and connected to the chassis, everything is fine. But if you were to switch the tweeter cable assembly so that the series components were on the "-" circuit path, then the chassis connection would short these components.
Not many crossovers are mounted this way, so it is rarely a concern. But when mounting the HF horns externally, having the crossover in an external box is a good and attractive solution. If the connectors are all mounted on a common metal panel, then this becomes a possibility.
Previous Topic: Unfolded conical basshorn
Next Topic: PI DJ SPEAKERS
Current Time: Sat Oct 24 11:53:30 CDT 2026
