Wayne Parham Messages: 19103 Registered: January 2001
A full set of data is provided for each component, showing response graphs and what-not. This should be considered the most definitive specification source. There is also a general description for each loudspeaker which shows prices and things like power handling and maximum output. These numbers aren't nearly as descriptive as the spec sheets for each component, but do give a general idea. For these, you should consider the power rating as a 70% point and the usable frequency range within +/-5dB a la Klipsch. Some are more conservative, some less.
