Home » Sponsored » Pi Speakers » What can I make with this sub box?
Re: What can I make with this sub box? [message #43182 is a reply to message #43181] Mon, 24 November 2003 12:43 Go to previous messageGo to previous message
The Kilomax 15 does very well in a 3ft3 box, though deeper extension results when a larger cabinet is used. You might consider cutting a panel to close the 15" hole and use a smaller driver instead, one that makes the volume larger in proportion to driver compliance. For 3ft3, you'll probably find more 12" drivers that are tuned to be used as subs.
Previous Topic: 4pi as a wedge monitor
Next Topic: Spec of Pi Speakers
Current Time: Tue Sep 15 16:27:03 CDT 2026
