Home » Sponsored » Pi Speakers » Journal of a First-time Builder - Pt 4: Functioning Speakers x2!
One of my favorite little two-way speakers [message #43125 is a reply to message #43118] Thu, 20 November 2003 11:49 Go to previous messageGo to previous message
Some people like piezo tweeters, and some don't. I suggest that one should listen to the KSN 1038 before they decide though. It is a distinctly different product than the KSN 1005 "lemon squeezer," which is the model that is most popular in low-cost PA speakers. I don't care for the KSN 1005 at all, but the KSN 1038 sounds much better, and I like it a lot.
The little one π's and two π's are entry-level products, and should be judged for comparison as such. However, as I said, I think the KSN 1038 tweeter is a good sounding device, particularly for their cost. It has flat response and low distortion, whereas the annoying KSN 1005 peaks in the vocal overtone region very badly, giving it a "spitty" sound which I suspect is the single biggest thing that people don't like.
I would not pair a high-efficiency 8" or 10" midwoofer with a 1" compression horn because this is to essentially have two midrange devices. If building a four-way, then a transition from 8" or 10" midrange to 1" compression horn is perfect. But if building a two-way system, I'd rather have a tweeter that is tuned a bit higher because that allows the system to deliver greater bandwidth. After all, a 1" compression horn shares over three octaves of operating range with high-efficiency 8" or 10" speaker, so pairing them together wastes a lot of bandwidth.
One of my favorite little bookshelf speakers of all time used a JBL Profesional Series 2115 - which is an 8" full range midwoofer - paired with a KSN 1038 tweeter. The only parts used were a 0.5mH coil in series with the (8 ohm) woofer and a 0.33uF capacitor in series with the tweeter. The coil tamed some rising response in the 8" driver and the capacitor attenuated the tweeter to match. Functionally, the speaker was crossoverless, like current models. This was a "Professional Series one π" speaker, and it combined a $200.00 JBL driver with a $10.00 piezoelectric tweeter, and it was probably my most popular model in the 80's. Sounded fantastic, and there are still many, many units out there, with happy, long-term owners.
Previous Topic: Woodfinishing experts...seeking advice
Next Topic: Pi seven internal volume
Current Time: Sat Nov 07 00:55:30 CST 2026
