Home » Sponsored » Pi Speakers » Journal of a First-time Builder - Pt 4: Functioning Speakers x2!
Re: Recom for Horn? [message #43120 is a reply to message #43119] Thu, 20 November 2003 08:50 Go to previous messageGo to previous message
It may work since the alpha 10 goes pretty high and the 50 has 2500 fs an octave below xover but you would have to run the numbers through some xover design program to be better informed. I would first ask Wayne since he is most knowledgeable and I would imagine you are not the first to be disatisfied with the piezo. I would think that the 2002 would sound great and you would be half way to a theater 4pi for the future as a thought. The apt 50 is 102 db eff. so there would need to be serious padding. Its hard to recommend without having heard that combination. Good luck and keep us posted.
Previous Topic: Woodfinishing experts...seeking advice
Next Topic: Pi seven internal volume
Current Time: Sat Nov 07 00:56:08 CST 2026
