Home » Sponsored » Pi Speakers » Horn-Loading a Delta 10
Horn-Loading a Delta 10 [message #43035] Fri, 14 November 2003 22:36 Go to previous message
DasDas is currently offline  DasDas
I want to build some new boxes for my 4way PA (mid-high), consisting of Delta 10 + 1.4" (altec 299). I already built the Dual 15 which will cover the 80-250hz area. The box I need to build must have the outside dimensions of 36" x 21 1/4" x 30" and 13 3/8" rear width. The horns I have are the Altec MR564 which is a 13x13 horn. I could use some other horn, but for now that's what i have. And that leaves me with roughly 21 inches of total height for the Mid Horn. The HF horn is a 60x40 horn, so the mid horn should be something like that. Is there anything that can be done for the Delta 10, in such space left? I already built the outside box, so all I have left to do is make the mid horn and stick it in there. Can anyone help me, or does anyone have any ideas??
BTW, I have no experience whatsoever using hornresp or designing horns. I have tried using it, but seems kinda complicated. Thanks a lot for your help
Previous Topic: AC cct troubles
Next Topic: Another side of the small and cute vs. big and efficient debate:
Current Time: Sun Nov 01 11:13:48 CST 2026
