Home » Sponsored » Pi Speakers » when designing horns,remember to..
when designing horns,remember to.. [message #42974] Mon, 10 November 2003 02:30 Go to previous message
toxicport.e is currently offline  toxicport.e
....make enough space for the woofer to be used ;-P
is 9mm enough clearance from woofer magnet to the horn baffle?
hopefully in real life there will be that much,i think il route it otherwise.
-or perhaps i should optimise it further to use up that last few mm :-)
i think il have to redo this one with 25mm MDF where possible
not long now left with CAD work for this 40hz beastie!!
Previous Topic: Journal of a First-time Builder - Pt 2: Veneer and Planing
Next Topic: DIY PI with Tube Components questions
Current Time: Sat Nov 28 18:56:40 CST 2026
