Home » Sponsored » Pi Speakers » Port Location Question for Towers
Port Location Question for Towers [message #42944] Fri, 07 November 2003 07:14 Go to previous message
I'm having some problem deciding where my port should go on the Pi Towers. Wayne has mentioned that it doesn't matter whether its on the front or back, so long as there's room to breath.
If the port is cut on the rear baffle, how far away will the speaker need to be from the wall. Due to the Tower's size, I'd like to be able to place the speaker as close to the wall as possible. Feedback from owners of "stock" Towers?
If the port is cut on the front, would it be a problem if it's cut in mid-baffle (approx 6" below woofer)? I'd want the option to put things in front of the speakers.
thanks,
gar.
Previous Topic: JBL tent sale enclosure
Next Topic: Ping - ToFo
Current Time: Sun Nov 01 14:43:16 CST 2026
