Home » Sponsored » Pi Speakers » How to choose the correct Horn??
Re: Set your goals, model a design and build it [message #42937 is a reply to message #42929] Thu, 06 November 2003 23:19 Go to previous message
For the most part, the pattern from a conical horn is set by the wall angle. So a straight-walled horn with 30° side walls and 20° top and bottom will generate a 60°x40° pattern over most of its bandwidth. At low frequencies, where mouth dimensions get close to a wavelength in scale, mouth diffraction will start to set in. So the patten will narrow slightly, and then as frequency drops, it will widen considerably.
At the other end of the passband, throat and diaphragm size become more important. The larger diaphragms obviously cannot be used to as high frequency as smaller ones, and phase plug and throat throat size and shape set a limit on HF performance too, both in terms of amplitude response and directivity. As a result, a 1" exit driver is capable of greater HF extension than a 2" exit driver, all other things being equal.
Previous Topic: Journal of a First-time Builder - Pt 1: Assembly
Next Topic: Anyone good with Speaker Workshop???
Current Time: Sat Nov 28 18:11:47 CST 2026
