Home » Sponsored » Pi Speakers » How to choose the correct Horn??
Re: Set your goals, model a design and build it [message #42929 is a reply to message #42922] Thu, 06 November 2003 11:38 Go to previous messageGo to previous message
Jeremy Bridge is currently offline  Jeremy Bridge
So what you are saying is that to creat a 60x40 midrange horn you simply need to have the angle between the vertical walls 60 degrees, and the angle between the horizontal walls 40? Seems almost to simple :) Perhaps I am misinterpreting.
Would there be a better horn choice to extend the HF response? I would rather only use one compression driver, if at all possible.
Previous Topic: Journal of a First-time Builder - Pt 1: Assembly
Next Topic: Anyone good with Speaker Workshop???
Current Time: Sat Nov 28 18:11:47 CST 2026
