Home » Sponsored » Pi Speakers » Any experience alpha 15 or another for open baffle ????
Re: Any experience alpha 15 or another for open baffle ???? [message #42884 is a reply to message #42879] Sun, 02 November 2003 11:43 Go to previous messageGo to previous message
I've never used the Alpha 15" personally.
Your concerns about driver QTS in dipole applications are understandable, but unnecessary. Anything with a qts below .8 (in some cases even 1) is considered qutie reasonable in closed box/dipole design. These drivers are not ideal for use in ported enclosures, but do fine in infinite baffle or dipole subwoofer configurations.
After all is said and done, qts has little to do with the sound quality of a driver (to a certain extent).
Having said htat, I don't feel the Alpha is a good option. It's unusual set of characteristics may give it a sweet sound for vocals and midrange, but it doesn't have the stuff to be a subwoofer. It also has very little xmax which is bad for a dipole setup, particularly if you are introducting low frequency EQ (which is generally what is done).
Possibly check out thise driver.
http://www.partsexpress.com/pe/showdetl.cfm?&User_ID=12695537&St=2137&St2=-81964001&St3=69117267&DS_ID=3&Product_ID=118185&DID=7
Adam
Previous Topic: mulling over crossover questions. Wayne? Anybody?
Next Topic: Field coil speaker replacement advice...
Current Time: Sat Nov 28 18:53:22 CST 2026
