Home » Sponsored » Pi Speakers » Why do horns handlice twice the power?
Re: Why do horns handlice twice the power? [message #42852 is a reply to message #42836] Fri, 31 October 2003 03:06 Go to previous messageGo to previous message
Walt is currently offline  Walt
If we put 2000W electrical power in, that power should also come out as sound and heat. Since a good horn can have a 30-50% efficiency this would mean that up to half of the input power is converted into sound. The other half will be lost as heat. A direct radiating system usually has only 1-10% efficiency so the coil has do dissipiate a lot more power. Therefore the horn will handle more power!
Best regards,
Walt
Previous Topic: Pi System Plans
Next Topic: Suggestions wanted!
Current Time: Wed Nov 04 06:49:38 CST 2026
