Home » Sponsored » Pi Speakers » Single Driver doubter no more
Re: Single Driver doubter no more [message #42760 is a reply to message #42759] Tue, 21 October 2003 18:13 Go to previous messageGo to previous message
I know what you mean. A simple little system like this can sound pretty good with a watt or two.
The first few recent popular single driver systems I heard kind of sucked, to be honest. So I had a somewhat biased opinion really, and thought I wouldn't really care much for most of the other similar offerings.
But I heard a really surprising little setup at Phil Wilson's house. It was a Fostex unit; Maybe Phil will chime in and tell the model number. Sounds pretty good, to tell the truth.
I guess it stands to reason that some products are better than others, and that there is probably a bit of personal preference that goes in there too. Seems to me that a guy can make a neat little minimalist system with the right parts. And the "right" parts for this application probably aren't necessarily all that expensive.
So while some might worry about distortion from running such high bandwidth to a single device, when the drive circuit is a little bitty two watt tube amp, there's just not a lot of movement there to distort. It really becomes a non-issue with the flea-power amps. Looks like a lot of fun and it sounds pretty good too!
Previous Topic: anyone near Ottawa,ON for Pi audition?
Next Topic: Newbie, need help about series speaker
Current Time: Sat Nov 07 00:01:44 CST 2026
