Home » Sponsored » Pi Speakers » Altec 416C and Altec 288C on 311-60 horn
Re: New Midrange Horns coming to a neighborhood near you! [message #42708 is a reply to message #42705] Wed, 15 October 2003 06:06 Go to previous message
Larry Acklin is currently offline  Larry Acklin
Be aware- wood horns in the bass/bid region are difficult to keep from buzzing (as if you didn't know that...) EAW uses thinner bendy (1/4"?) plywood to make the flares, and fills the back side void (behind the flare to the case) with expanding foam. (just like the 10 pi) My fiberglass horns are rigid enough that no foam is needed- but I have a big case around them for portability.
Boy, nothing like a fully loaded 3 way system, with about 2K watts per side.... (outdoors- 30 ft back...)
Larry Acklin
Previous Topic: Weekend At the Martinelli Estate
Next Topic: Anyone in central Florida have Pi's?
Current Time: Sun Oct 18 10:11:07 CDT 2026
