Home » Sponsored » Pi Speakers » Horn advice
Horn advice [message #42689] Tue, 14 October 2003 08:11 Go to previous message
Andrewbee is currently offline  Andrewbee
Hello Wayne,
I would like to try a pair of your horns. My room is 15'W X 37' long.
I do not want to "rock out" but want good bass down to ~40 cycles.
I plan to use a Fostex driver on a open baffle from ~ 100 cycles up and to bi-amp. I will be seated ` 20 feet from the speakers
Which set of horns your horns would you recommend and with which drivers?
Thanks
Andrew
Previous Topic: Theater 3 Pi plans
Next Topic: Great Tube Art
Current Time: Fri Nov 13 08:09:19 CST 2026
