Home » Sponsored » Pi Speakers » Altec 416C vs JBL 2226 in a 2-way system
Re: Altec 416C vs JBL 2226 in a 2-way system [message #42678 is a reply to message #42677] Sun, 12 October 2003 08:35 Go to previous messageGo to previous message
spkrman57
Jerrod,
The 416's are much better in a LARGE room. I have much better luck with the 2226's in my 12' X 16' living room. Not to mention for best results, the 416's like a 8 cu' cabinet to be at their best. I also like the 2226 for least amount of crossover parts if crossed over @ 1600hz. I will say that the 808's on the 511B horn crossed over @ 500hz will give you more detail on those little heard sounds in the background. I was playing Emerson Lake Palmer(Best of) and it seemed like I could hear the synthesizer breathing, those little obscure sounds that are lost in your average direct radiator speaker systems. My best listening spot is in the kitchen, which is behind the living room with opening 4' X 5' between the two rooms. That is only way to get back about 12' from the speakers. Other than that, horn speakers don't do well in "near-field" listening scenarios. If you have the room, and smallish push-pull tube amps, the Altecs are definitely a treat, but my modest(really small) house does not allow for such luxuries.
Cheers, Ron
Previous Topic: audiphile 3-way request
Next Topic: Wayne, JBL 2118J or JBL 2123J?
Current Time: Sun Nov 01 03:26:42 CST 2026
