Home » Sponsored » Pi Speakers » A bunch of questions
Re: 4 Pi [message #42647 is a reply to message #42627] Wed, 08 October 2003 19:23 Go to previous message
It would be my opinion that the Theater series 4 Pi would be the best bang for your buck. They work well with SET amps and are very easy to build for a first time project. Corner horns are significantly more challenging and costly.
If the overall dimension of the Theater 4 is too large. Step up to the Stage series 4 Pi.
MDF is inexpensive and a great substrate for veneer. Other than being easy to machine it can be challenging to work with. Russian, Baltic and Fin ply is the best choice. It comes in 5 x 5 sheets and is not always economical. Home Depot sells some fairly decent birch ply for around 36 bucks. pick up two sheets of this and build a speaker.
Bill
Previous Topic: Hi Guys! How about the ESG1 in a Theater 4?
Next Topic: Brother, can you spare a few screws?
Current Time: Sun Nov 01 07:14:32 CST 2026
