Home » Sponsored » Pi Speakers » crossover questions...
crossover answers [message #42637 is a reply to message #42629] Wed, 08 October 2003 14:40 Go to previous message
You answered your own question - You can put a resistance in shunt to set the load. If the compression horn needs padding and/or HF compensation, you can form a voltage divider and also be able to use it to set filter Q and high-frequency augmentation. Alternately, you can use a transformer for impedance matching. It's all a balancing act, of setting goal and priorities and building to suit.
Previous Topic: THD woofer measurement-what mic
Next Topic: Hi Guys! How about the ESG1 in a Theater 4?
Current Time: Sun Nov 01 06:26:18 CST 2026
