Home » Sponsored » Pi Speakers » Great Plains Audio Club Meeting
Re: Great Plains Audio Club Meeting [message #42393 is a reply to message #42392] Mon, 08 September 2003 12:33 Go to previous messageGo to previous message
footsurg is currently offline  footsurg
The amp says "250 Watts" in small letters on the top plate and that is the total measured power, but the amp is actually pushing 125 watts per channel in stereo. If you remove the bottom cover of the amp there is a place to insert a specialized metal pin that will bridge the amp into mono. If you do that, then it will push 250 watts into one channel at 8 ohms. There is also a 4 ohm and believe it or not a 2 ohm tap to choose from as well. I hope this clears up any confusion regarding the output of the amp.
Mark
Previous Topic: tiniest Pi speaker
Next Topic: Flush mounting and diffraction
Current Time: Mon Nov 02 02:44:59 CST 2026
