Home » Sponsored » Pi Speakers » wayne- lab12 available
wayne- lab12 available [message #42362] Fri, 05 September 2003 00:09 Go to previous message
toxicport.e is currently offline  toxicport.e
Choice
-a labsub with ONE lab12,
-or a labsub with ONE lab12 + flare extension
or-
-my own basshorn with lab12woofer
i know the labsub is the best way to go,but will be abit wobbly response if its used as a sofa NEAR not in proper corner position..
i can only afford ONE lab12 per box,dont need PA levels of output and wont be using 2kw.
should i take the hard road and use my own LONG horn ? its hard to optimise internal volume :-S
thanks
Previous Topic: martin audio em 26 upgrade
Next Topic: Hi Wayne, logo question
Current Time: Sun Nov 01 17:28:55 CST 2026
