Home » Sponsored » Pi Speakers » Voice Coil Inductance
Re: Voice Coil Inductance [message #42306 is a reply to message #42305] Fri, 29 August 2003 22:27 Go to previous messageGo to previous message
Hey Wayne,
Adire Audio, in their technical notes section has an article on voice coil inductance. Its located at http://www.adireaudio.com/tech_papers/woofer_speed.htm
If you have the time to read it, can you please go through it and tell me your thoughts. Its really just making a simple point, but a point nonetheless.
If we go by what that article has to say on inductance - that it holds the signal for a bit then "lets it go" (which is basically what inductors do) - do you think that the motor acting as an inductor will hold low frequencies for longer than high frequencies? Or would it act sort of like a constant delay like a flat GD curve?
I believe there are some that place all this emphasis on voice coil inductance, but they dont even know what it is. Thats why I'd like to get a better picture of this aspect.
BTW: On DVC woofers - wiring the VC's togethor in series doubles Le, and parallel halves it. I guess thats because in series the wire length is seen as doubled (which explains why Bl is doubled with series wiring). In parallel, for some reason it doesn't affect BL at all... Siegfried Linkwitz says on his website that wire length is not made any longer or shorter in parallel so BL is not affected in parallel wiring. But parallel wiring does halve the Le value. Why is this? Linkwitz also said voice coil inductance has little influence on low frequencies.... is this true? If so, then... we could say that for subwoofers, Le is not important. And on midrange/high frequency units inductance is always going to be low anyway, because they are tuned higher, so its not important to know what Le is on these units either. Or is this too simplistic?
Thanks!
Adrian
Previous Topic: Time to bake a Pi?
Next Topic: Interpreting speaker response curves
Current Time: Thu Nov 05 20:09:41 CST 2026
