Home » Sponsored » Pi Speakers » measurement questions
measurement answers [message #42281 is a reply to message #42280] Tue, 26 August 2003 13:00 Go to previous messageGo to previous message
What we're looking for are impedance values at specific frequencies. So, for example, DC resistance is impedance at 0Hz and Zmax is impedance at the resonant frequency. Zmax is described by a frequency and an impedance. If you measure voltage with a scope, you'll see peak values and can find RMS by multiplying by 0.707. If you measure with a DVM, you'll read RMS values and can calculate peak by dividing by 0.707. As for SPL, sure, you can put a microphone 1 meter away and supply a 2.83v test signal to find the 2.83v/M level, or whatever levels you wish. But below 100Hz, the cabinet will have a lot of influence so keep that in mind. For that matter, so will the room unless you do the acoustic measurements outdoors.
Previous Topic: Interpreting speaker response curves
Next Topic: Back from the Vet and de-Wormed
Current Time: Sun Nov 01 15:17:46 CST 2026
