Home » Sponsored » Pi Speakers » measurement questions
measurement questions [message #42280] Tue, 26 August 2003 12:06 Go to previous message
artsybrute is currently offline  artsybrute
Hi Wayne,
Some questions regarding measuring speaker parameters:
1. "So simply measure the DC resistance of the driver with an ohmmeter, and use the impedance found when measuring the driver's resonant frequency for Zmax." I'm missing something here. All the tests until this point seem to give frequencies, not impedances. How do I determine the impedances Zmax and Zmin?
2. It seems that the scope is used to determine highest voltage and .707 times that. Can I just use a voltmeter instead?
3. When taking these measurements, is there a way to determine the speaker sensitivity? Should I just use an SPL while running the 1 volt RMS with the resistor? Will sensitivity change unequally for the drivers due to their different ensclosure volumes?
TIA
Previous Topic: Interpreting speaker response curves
Next Topic: Back from the Vet and de-Wormed
Current Time: Sun Nov 01 15:16:51 CST 2026
