Home » Sponsored » Pi Speakers » Adjusting the capacitor value on the tweeter attenuator
Re: Adjusting the capacitor value on the tweeter attenuator [message #42218 is a reply to message #42217] Tue, 19 August 2003 12:42 Go to previous messageGo to previous message
You're right that parallel connections for capacitors add their values, so having 0.33uF and 0.47uF connected in this way gives you 0.8uF in-circuit. I'm not sure the Radio Shack meter would be very accurate above 10kHz, but I'm not surprised it would show a little more on the scale when the caps were connected in parallel.
You might try the 15dB circuit and see if it is more to your liking, and you can always manipulate the values of R1, R2 and C1. But I personally wouldn't want to use much bypass capacitance with higher-value attenuators. Once you get past 10dB or so, I don't like bypassing as much of the attenuation in the top octave with PSD2002's, because they already have pretty strong output above 10kHz.
Previous Topic: Who powered up all their amps at once?
Next Topic: 10 Pi horn as an electric bass cabinet
Current Time: Fri Nov 27 04:34:53 CST 2026
