Home » Sponsored » Pi Speakers » because this forum is good,il post here
2226h set up, its not the best.. [message #42211 is a reply to message #42202] Mon, 18 August 2003 01:23 Go to previous messageGo to previous message
toxicport.e is currently offline  toxicport.e
what if the current is not in phase with the voltage.??
HELP
btw jbl2226h in room-im getting high excursion wayne!!!! whats going on!?! :-S
my excursion is about the same as my 8inch on a conical pipe with the SAME amp.
to get similar midbass loudness i have to turn the amp up about 1/4 way around but ofcourse i get huge 33hz which wasnt there!.
also,if i have NO active filter,the highs of the sub, are SO LOUD like 20db or something crazy,that i turn my amp back to where i have it with my 8inch,sounds equal volume ,but little or non detectable bass.
is this the effect of the EBS? i didnt expect it to be that much!
only 5db lower at worst ,92db efficiency,
which is supposedly the efficiency of my 8inch conical pipe!
will get 240watt jaycar amp sometime.
im afraid how much excursion il get.i wish i could measure it somehow.
and no im not playing 10hz sine :P
Regards,
_Mike
Previous Topic: How do you tell when a horn "unloads"?
Next Topic: Aluminium vs plastic horns, third-order vs fourth-order crossovers...
Current Time: Wed Nov 04 15:14:12 CST 2026
