Home » Sponsored » Pi Speakers » Crossover help
1.6kHz with Zobel and L-Pad [message #42167 is a reply to message #42159] Mon, 11 August 2003 00:55 Go to previous message
I'd go with a ~1.6kHz crossover. For a coaxial arrangement, I might be tempted to use a symmetric crossover. As for the top-octave, it really looks pretty good and so I wouldn't add more energy there. Just use an attenuator to match the Beyma tweeter level with the Eminence midwoofer.
I think you will probably want a Zobel on the Eminence midwoofer, but for the tweeter horn, a series/parallel L-Pad arrangement that attenuates 10dB would be great for double duty - attenuator and damper. Give that a go and check your measurements to see where you're at. If the L-pad doesn't damp the circuit enough, try some different values and maybe even go with Jeff's suggestion of a tank circuit (notch filter) which will act as a resonating damper.
Previous Topic: Great site
Next Topic: Tweakin' Two's
Current Time: Wed Nov 04 01:15:14 CST 2026
