Home » Sponsored » Pi Speakers » Family Album finally pried from ex's bony claws
Re: This note's for you [message #42162 is a reply to message #42151] Sun, 10 August 2003 17:24 Go to previous message
CurrentlyInebriated is currently offline  CurrentlyInebriated
Hmmmm........guidelines............
wellll.......if you're sitting and playing as opposed to standing, the woodwind looking part top should be about reach straight out and touch high. Then you'd have about 2-6" of rod and then the desk. I bored the hole with a long bellhangers in a piecce of copper pipe on the tail of the lathe so the 3/4" dowel would be long enough to permit raising the desk for both sitting and standing. Also made the junction of dowel an desk an arc that pivots on a piece of 1/4" round brass stock with 4, I think,. index points for tilt. Drilled out and tapped more brass for the brass key that holds the dowel in place. I made the horizontal bookrest protrude an inch with a vertical piece dadoed on to hold something as bulky as one of those pale yellow Schumann books. mahogany for the turning and sliding dovetail tripod legs and Bubinga for the desk which is joined with mahogany splines.
Wish the picture was better. It's my masterpiece.
Previous Topic: Using 2 different woofer?
Next Topic: Great site
Current Time: Tue Nov 03 05:38:14 CST 2026
