Home » Sponsored » Pi Speakers » Why a bass guitar enclosure build this way?
Re: what can a single 12 be used in? [message #42160 is a reply to message #42158] Sun, 10 August 2003 15:38 Go to previous messageGo to previous message
That's hard to answer. You don't, by any chance, have the Thiele/Small parameters for this unit? If not, it's more a matter of experiment what kinda box will work the best. For a 12" instrumental driver, I'd imagine a box between 2-3½ cu.ft. (~56-100 liters) would work - one could try tuning it to 40-50 Hz, & if it got too bass heavy & boomy, simply close the reflex openings... Then you'd have a closed box that probably wouldn't go very deep, but, as mentioned in a previous post, going deep isn't that necessary (or advantageous) even with bass guitar boxes. But why not try building a box ~2½ cu.ft. & see - only cost the wood & a little work anyway :-)
Previous Topic: Effect of gaps and back chambers.........
Next Topic: This Titanic sailed into port!
Current Time: Mon Nov 02 14:39:08 CST 2026
