Wayne Parham Messages: 19093 Registered: January 2001
You'll probably blow the tweeter at very low power levels (like under 10 watts) if you remove the coil. I'm confident you've correctly identified that as a shunt coil forming a second-order high pass filter. Same thing with the crossover point - It probably can't be pushed any lower without damage to the tweeter.
