Home » Sponsored » Pi Speakers » Choose a match loudspeaker and x-over question.
System possibilities [message #41982 is a reply to message #41980] Sun, 20 July 2003 19:12 Go to previous messageGo to previous message
You can use an attenuator to bring down an efficient subsystem to match other less-efficient subsystems. This is a solution that will work with a single amplifier. But it obviously means that overall system sensitivity is set to that of the lowest rated component.
If you choose to bi-amp or tri-amp, you can use more gain and power for a subsystem that is less efficient instead of attenuating. But this requires multiple amplifiers and more hardware.
Previous Topic: This is what happens when you put 2 Delta Pro's, etc,etc...
Next Topic: high effeciency 8"
Current Time: Fri Oct 30 10:11:32 CDT 2026
