Home » Sponsored » Pi Speakers » Theater 4 Pi Update
Re: Theater 4 Pi Update [message #41967 is a reply to message #41965] Sat, 19 July 2003 07:04 Go to previous messageGo to previous message
wasteh202 is currently offline  wasteh202
I use a hand truck to move around the 2Pi Towers that I build. I used the hand truck even in the later stages of construction and after moving them around to different rooms.
You just need to take a bit of care so you don't scratch or ding the wood or finish.
I hope you have one (hand truck), if not they can be obtained at the hardware warehouse store for about $30.00 and you will find other uses for it in the future.
Previous Topic: 2 Pi Tower XOver
Next Topic: There's just something about wheels
Current Time: Sat Nov 14 15:54:37 CST 2026
