Home » Sponsored » Pi Speakers » I need some good PA designs that can work for JBL drivers!!!!!!!!
Re: I need some good PA designs that can work for JBL drivers!!!!!!!! [message #41920 is a reply to message #41914] Mon, 14 July 2003 11:44 Go to previous message
Larry Acklin is currently offline  Larry Acklin
Don- I agree with Wayne's suggestion of the 10 pi. Put a pair on the FLOOR, each side, next to each other, so the horns couple, and you will get loads 'o bass. Two horns in close coupling get you more and a lower cutoff. (I would not go below 60 Hz tho.) Your design should include some 12" mids- 200-300 hz crossover(?) in bass reflex boxes- I would guess 1 ea in 2 boxes per side, and 1" exit compression drivers coupled to HF horns- possibly the PSD2002 Wayne is fond of. I would configure a pi aligned box for one 12" and a horn.(total 2 mid/high boxes per side) on top of 2 ea. 10 Pi boxes per side as bottoms.
Configure the mid/tops with Waynes crossover design (suggest about 1500 hz or higher)from mid to HF, and plan on bi-amping the bottoms and mid/tops.
Expect to use a minimum of two amps, one in stereo mode with 2 bottoms per side, and the inputs (only) Y cable connected.
The other amp same way, 2 mid/top boxes per channel, with the inputs Y connected.
Active crossover (behringer or peavey, or whatever)
LOTS of AMP! Figure a pair of Crown XLS602 or QSC RMS1850 as a MINIMUM.
Stage monitors are a whole different topic.
(been doing this a lot this summer)(outdoors,too)
Larry Acklin
Previous Topic: Pi theater 3 or 4 and Adire 12.1
Next Topic: Theater vs Thermionic 3pi
Current Time: Thu Oct 29 05:17:45 CDT 2026
